Worked on the AC today. It blows cold but I had to rewire some of it.
The relay to run the compressor does not get 12 volts. I jumpered the green with yellow tracer coming out of the "Auto Compressor Control Unit" behind the glovebox to the 12v from the AC switch. Works great. The signal goes through the two way pressure switch on the dryer and the temperature switch on the thermostat housing. Since the pressure switch lets the compressor run I know I have a full charge.
Any ideas on why the "Auto Compressor Control Unit" will not supply the 12 volt signal?
Also the signal seems to depend on the "MFI Control Unit" What is the "MFI Control Unit" and where can I find it?
Car had the KeyDiver chip if it matters.
