Clutch engagement ( more pics )
boostx
Orlando, FL
Is this enough movement for clutch engagement and disengagement?
The second picture is with the clutch pedal to the floor
CP
West Simsbury, CT
What's happening? Did you just replace the clutch? Is the slave boot leaking fluid when squeezed?
boostx
Orlando, FL
The tranny was just replace the one I took out was extremely hard to shift.
Also the clutch was not 100% disengaging when the clutch is press.
I will be changing the clutch later today /ubbthreads/images/graemlins/banghead.gif i should have did it when i took the tranny out. /ubbthreads/images/graemlins/bawling.gif
CP
West Simsbury, CT
Everything was adjusted correctly, and it was still hard to shift? So this trans is currently OUT of the car?
boostx
Orlando, FL
yea we tried adjusted it was still engaging when the clutch is press.The tranny i just put is shifting fine as per the original user.
boostx
Orlando, FL
nope
OldHairyBastard
Northern Chicagoland Area
You might need a master and slave. Also you can use a thick or a couple of thin washers behind the pivot ball to help out with the disengagement issue and or an extended rod. I had to install a new master, slave, hard clutch line, 2 washers & an extended rod to make my shift feel stock and disengage fully.
Jason G.
Anderson, SC
Those copper crush washers on your turbo oil feed line work good for shimming the pivot ball. I thought I was the only one to swap a tranny then immediately replace a clutch after getting the tranny done. /ubbthreads/images/graemlins/banghead.gif
boostx
Orlando, FL
I will shimming the pivot ball with two cruch washer.The cluch did not a come in yet. /ubbthreads/images/graemlins/bawling.gif /ubbthreads/images/graemlins/banghead.gif
boostx
Orlando, FL
this is what the clutch and the PP look like
bazeng
Melbourne, Australia
bent fork?
i just changed one out yesterday, the fork had broken in 1/2
from memory, there should be slightly more movement in distance than the pic..
did the slave bleed okay?
cOmpressor
Bay Area, CA
CP
West Simsbury, CT
I'll sell you one for $20 shipped. I used it for a few weeks until I figured out that the slave rod wasn't my problem. It's in mint condition.
In the third pic down- from looking at the PP and the "wear-ring" you have on the tip of the fingers looks like you also may have a bad TB.
CP
West Simsbury, CT
...the TOB with the plastic sleeve that wraps around the shaft (easy there Steve...take a deep breath).
SleepinGVR4
Danville, Pennsylvania
Always use new Throw Out Bearings when you replace your clutch. Only Mitsu.
Why only mitsu? I got one of South Bends clutches and used their TOB. Was that a bad idea?
