Replacing fluids on my GVR-4
MMCVR4
I'm planning on using BG Syncro Shift II (Part No. 792) on my transmission & transfer case and Redline Heavy Shockproof on the rear differential. How many quarts does the transmission / transfer and the rear differential takes?
271/2000
CP
West Simsbury, CT
I'm using a combination of Heavy Shockproof, BG2 and Pennzoil in my tranny right now. My Shep rebuild is going in next weekend, and he said he's starting to like 100% LW shockerproof for the tranny.
For the t-case and rear diff, I'm using Redline 75W90 gear oil with a little bit of heavyweight shockproof thrown in for good measure.
spartan
Sheboygan, WI
I just replaced the rear diff and t-case fluids last weekend, I just put in mobil 1 synthetic 75w-90. The rear diff was a pain to fill for me since I didn't have an lift or pit. I got it though, but not before getting some in my eye (that was fun)
powerplay
Norwell, MA
Thanks Wendy for answering the question.
CP
West Simsbury, CT
Thank you Scott for contributing to this thread /ubbthreads/images/graemlins/dunno.gif THIS page (vfaq) may answer some questions about DSM fluids as well.
For rear diff, t-case and tranny refills, I use a 2-3 foot section of clear Home Depot tubing that I can slip the end of a funnel into. On the other end, I've cut a small "V" in the rubber so that it can be squeezed together to fit in the fill holes. That way you can stand up and feed the funnel, instead of drowning in the stuff underneath the car.
JB
MA
He has a point Cy. The question was only about the quantities. Not the brand/mix/process of changing them.
powerplay
Norwell, MA
Thanks Joe. I have about had it with his constant thread jacking.
Scott
Hertz
Chicago, IL
Hey, Thanks to all of you for posting. /ubbthreads/images/graemlins/smile.gif
I've never replaced any drivetrain fluids besides tranny. Is that bad?
steve
NJ
That depends, are you the original owner. /ubbthreads/images/graemlins/ooo.gif /ubbthreads/images/graemlins/rofl.gif
GVR-4
Asheville, NC USA
I suggest buying the gear oil pump sold at many parts stores. It's got a long hose and pumps like a liquid hand soap dispenser.
Bimmubishi
Boston, Massachusetts
Hertz are you trying to Bump this? I think that this forum is your private sociology experiment.
round table et al... /ubbthreads/images/graemlins/devil.gif
Ted Andkilde
Windsor, Canada
I use one of these:
They're less than $10 at any industrial place -- buy a 4' length of clear urethane tubing to go with it.
Cheers, Ted
