JDM Galant VR4 Brake Master Cylinder?
JonnyRHD
New member
Canton
Looking for information on whether or not there is a USDM master cylinder that I can swap into a 90' RHD VR4 without remaking or rebending the factory lines. Seeing as they are located in opposite sides of the car I'm not sure if it will be possible or not. If not, does anyone know of a rebuild kit for these? Been having trouble sourcing one stateside.
Indianapolis, IN
You would have to compare it to a USDM part to see if they are the same size. If they are, I would think a rebuild kit would work. Also, if the USDM fit, you could just source some stainless brake lines instead of looking to bend/build new ones.
Cherry Hill, NJ
I know it's a different model, but a v6 master cylinder from a usdm Montero will work in my 4d56t JDM Pajero. Maybe the Galant is the same.
JonnyRHD
New member
Canton
Tried a 3000GT VR4 master based on photos and when it arrived it was nowhere near working. Nees to find a solution here pretty quickly. Car has been sitting for two weeks. Bummed.
AllanL
NV
does your rhd vr4 have abs or not?
below are the part numbers for the seal kit...
non-ABS: MB857841/MR235421
ABS: MB928042/MB928459
