ABS delete, rear delay valve?
Galant_martin
Austria
Hello,
i did the ABS delete a time ago (abs unit out, new prop valve on the firewall and new lines for the fronts) and now i want to install SS breaklines. Now a rear hard line broke and i found something new. There is a rear prop valve and a abs delay block. Should i just uninstall both and connect both lines? I need a bit of new breakline to one wheel so i would order 2 connectors too.
Its a 2wd with solid axle and disc break
