Galant VR-4 Forums » Galant VR-4 » Technical Discussions » 2g head radiator hose problems
profiesy
Newbie
Galant VR-4 org Post #: 1243573 posted 08/01/18 02:31 AM     Remind Me!  Send Private Message   Edit Post
Does anyone have a part number of radiator hoses for a 2g head swap into a vr4? The top is fairly easy but the bottom doesnt seem to line up.
Posts: 3 | From: port st lucie | Member Since: 10/30/16 | IP: (2601:58b:4101:8e) | Report this post to a Moderator
Eztoril
1450/2000
Galant VR-4 org Post #: 1243587 posted 08/02/18 11:46 AM     Remind Me!  Send Private Message   Edit Post
If you have a hybrid 7bolt/6bolt then you should have made sure the water neck, thermo housing, and water pipe are correct for the vehicle it's being used in or hose is correct to match. There are slight differences in these components, You may need to trim the hose slightly to make it fit. You should be able to get a lower hose from practically anywhere.
What Intake and water neck, thermo housing, and water pipe are you using? 1g or 2g?
Still want the part numbers? Here ya go
1g lower hose
MB356992
2g lower hose
MB906429
Edited by Eztoril (08/02/18 11:59 AM)
Posts: 51 | From: Irvine CA | Member Since: 08/31/16 | IP: (174.67.213.203) | Report this post to a Moderator
Eztoril
1450/2000
Galant VR-4 org Post #: 1243591 posted 08/02/18 02:33 PM     Remind Me!  Send Private Message   Edit Post
Purchase both lower hoses use the one that fits, return the other.
91 GVR4 1450/2000
2.3 Stroker
HKS cams
FP 3052
Spal puller
EVO MAF 3"intake
EVO8 560 injectors
EVO8 ECU tephramod v7
Walbro 255
FRH intake mani
EVO3 exhaust mani
44mm tial wg
EVO3 tranny
Posts: 51 | From: Irvine CA | Member Since: 08/31/16 | IP: (2600:387:8:f::b2) | Report this post to a Moderator
profiesy
Newbie
Galant VR-4 org Post #: 1244100 posted 09/14/18 05:34 PM     Remind Me!  Send Private Message   Edit Post
I ended up ordering a 2g lower and it fit with some trimming.
Posts: 3 | From: port st lucie | Member Since: 10/30/16 | IP: (2600:1006:b127:4) | Report this post to a Moderator
Generated in 0.094 seconds in which 0.083 seconds were spent on a total of 14 queries. Turbo powered.
