Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Radiator Fan Shroud NLA
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1243158 posted 06/29/18 01:04 PM     Remind Me!  Send Private Message   Edit Post
The radiator fan shroud is discontinued and NLA, part# MB605113, which sucks as mine has decided to disintegrate on me. The section nearest the turbo seriously feels like foam and breaks off like foam.
Dorman sells the whole thing, fan balde, shround, and motor, but the reviews aren't the best on it. Dorman part number is 620-327. Has anyone bought one? If the fan motor goes to crap, would the OE fan motor fit in it's place? Should I be looking at different aftermarket part that shrouds the whole radiator? Car currently cools fine, but living in the "South" isn't doing it any favors.
Posts: 380 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:6) | Report this post to a Moderator
Galant VR-4 org Post #: 1243159 posted 06/29/18 01:35 PM     Remind Me!  Send Private Message   Edit Post
I have no experience with the Dorman part in question, but I will just offer that the stock fan likely would not fit without some modification. Motor size, shaft length and fan blade design will all likely vary.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10651 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Eztoril
1450/2000
Galant VR-4 org Post #: 1243170 posted 07/01/18 01:37 AM     Remind Me!  Send Private Message   Edit Post
You can try to find a Hyundai one that fits. Research will be needed to figure out which one you can use from an elantra or sonata or other models. I would just cut the wires and wire into the factory vr4 harness. If you do find one make sure you get the connector also. Let us know if you find a oem fan w/shroud that fits?
Other option is just to buy a spal fan which is available with a slim fit option and they work great. I use a spal without a shroud and it does the job very well.
91 GVR4 1450/2000
2.3 Stroker
HKS cams
FP 3052
Spal puller
EVO MAF 3"intake
EVO8 560 injectors
EVO8 ECU tephramod v7
Walbro 255
FRH intake mani
EVO3 exhaust mani
44mm tial wg
EVO3 tranny
Posts: 51 | From: Irvine CA | Member Since: 08/31/16 | IP: (2600:387:8:5::5b) | Report this post to a Moderator
Eztoril
1450/2000
Galant VR-4 org Post #: 1243177 posted 07/01/18 07:41 PM     Remind Me!  Send Private Message   Edit Post
Looking through other threads about the cooling fan, I ran across one that mentions someone using a fan assembly from a 99-05 Hyundai accent. I'll look for it again and link it here.
cooling fan with 4" intake
91 GVR4 1450/2000
2.3 Stroker
HKS cams
FP 3052
Spal puller
EVO MAF 3"intake
EVO8 560 injectors
Walbro 255
FRH intake mani
EVO3 exhaust mani
44mm tial wg
EVO3 tranny
Edited by Eztoril (07/01/18 07:44 PM)
Posts: 51 | From: Irvine CA | Member Since: 08/31/16 | IP: (2600:387:8:7::57) | Report this post to a Moderator
467
mass moment of inertia
467/1000
Galant VR-4 org Post #: 1243185 posted 07/02/18 02:11 AM     Remind Me!  Send Private Message   Edit Post
Why not a decent used one? I think 88-93 Galant with DOHC motor should all be the same.
Posts: 889 | From: Fremont Ca | Member Since: 03/16/01 | IP: (24.6.21.118) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1243194 posted 07/02/18 10:02 PM     Remind Me!  Send Private Message   Edit Post
even the ones from the 92~96 mirage/colts should fit...
Posts: 249 | From: NV | Member Since: 08/05/08 | IP: (122.53.101.242) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1243196 posted 07/03/18 06:39 AM     Remind Me!  Send Private Message   Edit Post
Quoting 467:
There are not many out there anymore, but I am looking. There was one at a junkyard about an hour away, but I never had free time without the kids to go grab parts off of it. Called yesterday and they crushed it.
Posts: 380 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:4) | Report this post to a Moderator
91vr4auto
Newbie
Galant VR-4 org Post #: 1243219 posted 07/05/18 12:19 AM     Remind Me!  Send Private Message   Edit Post
Found this listed at RockAuto if it helps
click,1992,galant,2.0l+l4+turbocharged,1206278,cooling+system,radiator+fan+assembly,2181
Mike.
Posts: 16 | From: New Zealand | Member Since: 01/29/18 | IP: (49.225.227.209) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1243220 posted 07/05/18 06:10 AM     Remind Me!  Send Private Message   Edit Post
Fixed the link. CLICK
Thom
Posts: 824 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
kooter
Member +
148/2000
Galant VR-4 org Post #: 1243224 posted 07/05/18 11:13 AM     Remind Me!  Send Private Message   Edit Post
I made the mistake of ordering the motor blade and shroud from mitsu many many years ago. motor was like 396 dollars if I recall corretly. have it assembled somewhere in my garage. never installed in on the car. if your interested I can try to find the one that was on the car and see what kind of condition it is in. I believe it had a small piece broken off of it.
1991 galant vr4 nile black
JDM Transplant. 16g 510 injecters
102,000 miles
Posts: 255 | From: carpentersville, IL | Member Since: 01/13/11 | IP: (74.222.42.123) | Report this post to a Moderator
91vr4auto
Newbie
Galant VR-4 org Post #: 1243229 posted 07/05/18 03:01 PM     Remind Me!  Send Private Message   Edit Post
Quoting thomcasey:
Thanks, damn new-fangled interweb trickery!
Posts: 16 | From: New Zealand | Member Since: 01/29/18 | IP: (49.225.195.85) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1243237 posted 07/06/18 09:18 AM     Remind Me!  Send Private Message   Edit Post
Quoting thomcasey:
I know that there is aftermarket, that wasn't my question. My question was really would the OE motor and maybe blade fit in the aftermarket one as those are still good on my car, just in case the aftermarket one takes a crap. I like to have spares...
0 registered and 28 anonymous users are browsing this forum.
Generated in 0.114 seconds in which 0.089 seconds were spent on a total of 14 queries. Turbo powered.
