2g ecu in a 1g/gvr4
89Mirageman
Stantonsburg, NC
I did a quick search on google and found some info. Just wondering if anybody on here is running a 2g dsm ecu successfully? Is there a step by step writeup anywhere that shows you how to build the needed adapter? I've found the pinouts.
I'm thinking about tossing a 13g and some 450's on my colt since I have the parts laying around in mint condition. I also have two non eprom 2g ecu's. I would leave it stock with the 450's so no need for a chip or link.
Any help is greatly appreciated!
AllanL
NV
hey Chris, it's similar to the 1G to Evo ECU swap...
my galant is currently on an Evo3 ECU [using the appropriate 2G plugs and 1G harness]...and soon moving to an Evo8 ECU...
89Mirageman
Stantonsburg, NC
Did you solder up your own adapter to use the evo 3 ecu?
AllanL
NV
no adapters...did pigtail swaps.
will use an adapter harness for the evo3 --> 8 swap though.
swe_gvr4_1991
Sweden, Alingsås
I'm with Allan here. The EVO123 ECU is the easiest direct replacement. The plugs are 2G style as mentioned. The CAS is the same type as on our GVR4, Lancers, etc which makes this swap easy compared to a 2G USDM ECU.
CutlassJim
Manchester, NH
When you say 2G ECU do you mean the early metal case ones or the later black plastic kind? If I was going through all the trouble of making an adapter or swapping the plugs I would run the later programmable unit.
89Mirageman
Stantonsburg, NC
I have two of the early style metal case ecu's. Honestly it sounds like I need to just sell those and get a 1g turbo ecu.
AllanL
NV
easiest option Chris! /ubbthreads/images/graemlins/idea.gif
though i've edited a bin file off of a metal-cased 2G AT ecu a couple of yesrs ago [with Ceddy's indirect support]...
