EProm ECU Error Code
Galant_martin
Austria
Hello,
I had bought an EProm ECU for my Galant E33 (4G63 DOHC Front Wheel Drive) and installed an Ostrich 2.0 with stock E33 rom.
But if i start the car with it, it runs fine but gives me CEL and stored Error 42. 42 is for Fuelpump afaik. If i swap back to stock Non-EProm Ecu there is no error.
Any ideas?
Greetings from Austria
Martin
swe_gvr4_1991
Sweden, Alingsås
This is because the E931 code is looking for the fuel pump drive signal on ECU pin #13.
Make a new XDF scalar with the address 6987 (or E987 with offset) and replace the 5A with 01 and the CEL goes away.
This CEL is because your FWD car does not have that wire populated in the harness.
Galant_martin
Austria
Ok i will look on this and than we will see /ubbthreads/images/graemlins/cool.gif
Or i test the E901 GTi Rom.
Galant_martin
Austria
Me again.
I just tested 2 Roms.
E441 (from Dynamic 4/ 4G63 NA with 4WD and 4WS)
E901 (from GTi 4G63 NA with FWD and ECS)
on both it idles fine but gives me CEL
and on my ECU connector Pin 13 for "Control Relay (Fuel pump drive signal) is connected ?!
here is a pic from hex editor, is this the adress you mean?
AllanL
NV
I believe Kim was referring to the E931 bin when he mentioned changing the value in 6987.
In the 32k bin for E901, it is 5B4B. in the 16k bin with the pic you posted, that address you encircled is incorrect. 1B4B is the position indicated by the green-red arrow in the pic below.
Use the search function in your bin editor, and search for the area where the string 'D5 40 01 5A' is present. I believe this string is at 2951 in your 16k bin.
Change 5A to 01.
Hope this helps.
Let us know if the CEL goes away after changing 5A --> 01.
Galant_martin
Austria
So.
I checked the 441.bin
The string started at "294E" with D5 and endet with 5A at "2951"
i changed it to 01 and it worked /ubbthreads/images/graemlins/wink.gif No CEL /ubbthreads/images/graemlins/cool.gif
Than i looked at the 901.bin
There is "D5 40 39 8F" at this position.
Im a bit confused, i had a eprom ecu befor and dont need to modifiy this?!
jnava
Arlington, Tx
Im glad that it wasn't an ecu issue.
edit: I would have gladly issued you a refund, but it seems it was a rom editing issue.
Galant_martin
Austria
Sorry. i forgot /ubbthreads/images/graemlins/frown.gif
BIG Thank You /ubbthreads/images/graemlins/worthy.gif
AllanL
NV
/ubbthreads/images/graemlins/rofl.gif
just glad you got it working...
