Tranny Help
Pano
New York
Got tuned Saturday made 400awhp and on the way home I got on it and heard a loud pop and my car shut off etc. So I pulled my tranny and a piece of the casing cracked and tore my clutch up. what I want to know is what cars have the same tranny as me. Its a TRE stage 3 but the casing looks different then other vr4 trannies I compared the pics to.
here are pics of my tranny and what snapped, any helpful input is appreciated
Not right yet. /ubbthreads/images/graemlins/wink.gif
Pano
New York
ah I tried to make the images bigger... tranny was painted over so I cant see any numbers or anything
BENE38A
New Zealand
Looks like a transmission from a 7 bolt 4g63, has extra bolt holes. The letters and numbers should be stamped on the bell-housing between the top two flanges that bolt to the block. Give it a sand and you should be able to pick up the letters and numbers.
Pano
New York
Thank you I found the numbers it us a W5m3 tranny 6 bolt I believe. Any idea what's my best bet on location one ?
Quoting Pano:
My suggestion is contact TRE if it is a TRE built unit. He usually has cores and spares around. Likely he can take care of fixing it with used parts.
Pano
New York
So it's been a few weeks since the casing cracked and I finally got the car back together with a new twin disc. I figured out why my casing cracked in the first place, my tranny bolts coke loose way to easily. I put lock tight on them last night bc they even came out after I put the new tranny on. Any ideas why they come loose?
Vibration and bell housing flex.
Coltsfan
Tonawanda
Make sure you have both alignment dowels between the block and bell housing.
