COOLANT LEAK/HAS ANYONE ELSE RAN INTO THIS
chop91vr4
new haven indiana
I did the FIAV bypass rerouted the coolant lines and screwed in the FIAV all the way, well ever since I did that it seems that it increased the coolant pressure to wear I'm now fighting the top of the lower coolant hose leaking where it goes to the motor, so I replaced the hose and cleand the contacting points and put a new clamp and still once it gets upto temp before the fan kicks in it starts to seap from the top of the hose past the clamp and I have that damn thing cranked down tight. CAN ANYONE HELP????? /ubbthreads/images/graemlins/bawling.gif /ubbthreads/images/graemlins/banghead.gif
The pipe might have rust on it. Try cleaning the pipe up first.
coyotes
Seattle, WA
make sure the clamp and the hose are past the lip on the pipe and are lined up perpendicular, not cut sloppy or anything.
Also, heavy duty hose clamps are far more betterer. You could be tightening the clamp but it's just slipping on the worm gear.
I would call wherever you bought the parts from and blame them. Gotta be their fault. (joking)
ronkonkoma, ny
I replaced just about everything. I welded my fiav line closed. I have coolent leaking from a few places. I think I bought a faulty rad cap though. It should really be going into the overflow shouldn't it?
The cap only vents under excessive pressure, the vent does go to the coolant bottle. If you can get a pressure tester on the system, that would really help. Otherwise it's possible you overtightened the clamps, or possibly when you removed the old hose you accidentally bent the pipe out of round.
