help subaru sound with honda power
MRmeeTooxD
chicago, illinois
Help. I have issues on the car again back then it was 2 injectors.I get up drive my car an she drives perfect. As I shut the car off for 3 -5minutes as soon as I start my car. Bamm it has the subaru spell going on along with putter feeling ,an no power. Oww an check engine light. Is it possible for injecters to go bad with in 4months again.? Help:'(
Kibby
Baltimore,MD
In reference to parts going bad. When I bought my spec v new in 06, 3 months later the alt took a crap driving down the highway and didnt throw a battery light. Luckily it was morning dark and I noticed my headlights dimming dropped it off n it was replaced.
I got the bosch? (I think) brand injectors. They claimed more mpg which I didnt get. I bought them because my car was sputtering and found it to be a bad egr which I blocked off.
MRmeeTooxD
chicago, illinois
Well , thats weird see. Like my 4g63 doesnt have egr it has a block off plate . Everytime my car rest for over night she drives perfect again. But when I give her the 5min break thats when it drives like that. Im totally confused....
4Grim
Orlando FL
Sounds like a power transistor...when those go out, sounds like a Suby Boxer.
G
zompton
You sure you installed the right injectors?
strokin4dr
Savannah, GA
Quoting 4Grim:
+1
I've had a couple fail over the years.
Near Seattle, Washington
The title of this thread alone sounds like you've got a burnt valve or a blown head gasket. But the description makes itsound like you're just not firing on 2 cylinders. Check the coil pack and check the injectors again.
MRmeeTooxD
chicago, illinois
yes the blue top stock injectors are the same ones in there. I had the car on an did the process of elimination strategy.. I unplugged every plug from the injector one by one, making sure to quickly plug um back in. Sure enough, the last injector towards far right did make a difference in sound it stood the same . Now either I try to source one out. Good thing I have goodies on there way so I can just upgrade to my evo injectors...
