Right turn signal stays on
uncleben4rice
antioch ca,
I took 654 out for a fun pull and turn signal stays on. I pulled all the fuses and it won't go out. Pulled both lights also
Right blinker won't blink
Left blinker works.
AnotherNewb
Orlando, FL
Does this happen with the parking lights turned on? If so it sounds like a broken filament in one of the dual filament bulbs back feeding through the rest.
G
zompton
That means you won the race.
89Mirageman
Stantonsburg, NC
I've had this happen on a few older Mitsu's and it was always the stalk.
No, he means the turn signal switch. Can you be more specific about what you mean by "stay on"?
Does the light come on, but do not flash?
---then its a relay issue--- swap in a new flasher relay.
Or
Once you click the switch up for right hand turn and make a right hand turn do the signal keep flashing?
--- then the turn signal canceler ring is broke. swap in a new turn signal switch assembly.
Or
Does the turn signals light up and won't turn off even with the switch in neutral?
---bad buld, filament issue like mentioned, or a wiring short--locate and repair short.
does this happen with the Headlights on or off?
uncleben4rice
antioch ca,
Found the problem. I had a guy sitting in the back seat the other day and I did a pull. His weight pinched the wire that's under the seat. Wires fused together Blue and Red.
G
zompton
Damn street racers. /ubbthreads/images/graemlins/rofl.gif
