Flow Benches are like dynos.....numbers can be altered
Cool you posted this and cool all this was complied at one spot but every bench is a little different, temp and barometric pressure of the day tested etc etc all come into play. Real truth is the before and after using the same head on the same bench. Hell Chris Beran as far as I know still has the HP/mph record with his heads on Mike's Evo and he built his own bench....sorry want give up his secrets but its built from scratch. Damn I need to call him one day. Anyway its all about the area under the curve, If you plot all the numbers on a graph and look at the mid lift numbers instead of top flow a head with more area under the curve makes for a faster car....period. Each cyc;e the valves are closed once and open once but pass through the mid lift numbers twice. Always look at those numbers and pay attention to the top lift number advertized. Lots of places advertize their .600 or .700 lift numbers but if your car has a .500 lift cam .6 and .7 mean about squat sh*t.
Now before I open up the 1g head vs 2g head debacle I'll shut up about the little port boat anchor pos heads. /ubbthreads/images/graemlins/devil.gif
