I can't figure out how to get into the door, properly, so I basically
jiggled the wires from the cluster end of the loom, and tried the switches.
(1) I read somewhere that if the passenger side switch is bung, then
everything is bung. so i have swapped all the switches around, nothing....
(2) I tried cleaning the connections on the drivers side buttons, and
re-soldered all the connections incase of dry joints, nothing...
(3) blew out the sliding switches with compressed air, nothing...
(4) tested the plug that joins the switches with a volt meter, nothing...
(but then again, i haven't got a clue what wires to test against, i
may need to try this one again)
(a) Where can i get wiring diagrams for the loom? showing all the colors?
I think the problem is to do with the relay, but i dont know which
one controls the power windows. All the relays have different plugs
so its difficult to try out each relay one after the other in each
of the sockets. Not only that, im limit with what i have in relays.
If you or someone could tell me out of any of these images is definitely
the relay for the power windows i would appreciate it.
(b) Another thing too, is that I have come across dozens and dozens of
different fuse box configurations for 1gs. Is this car even a 1g?
Parts of this vehicle seem like a combination of 1g and 2g? is that right?
Most of the diagrams i find say that the 3rd fuse (10A) on that colored
diagram not only controls the heater and defogger, but also the power
windows. But because the power windows don't work (barely) at all, so
i can't confirm that fuse position also contributes to the power windows.
They dont move slowly, they jolt for a millisecond and then nothing for ever!
Perhaps the power windows are allowed power through another fuse location?
I think a previous owner has shorted some wires or something, because
the heater works sporadically, sometimes it will pulse air out, sometimes
it behaves. but its display is completely blank...
(c) NOW! if the fuse is shared between this bung heater unit and the
power windows, could this give me this weird power window problem?
Because the windows will work when they want to, its just that its soooo
random, with a strong chance of nothin''''
(d) So where would the location of the power windows relay be on any of these images??
Because it has to be some sort of rusted relay thats got worse and worse to energise over time.
Thank you so much for your reply I'm glad I can contribute my problem for future reference.
