belize1334
I noticed this issue on a long hot drive back from Salt Lake City this weekend. The car breaks up under load but the severity of the condition is strongly dependent on how long the engine has been running and how hard it's working. For instance, if I take it out, warm it up, and get on the freeway it runs really strong up till about 10psi and 4500 rpm and then it starts breaking up. But, if I've been driving it for hours and I'm pulling a hill it will break up at 0psi and 3000 rpm. At that point, if I crest the hill and let it coast down the back side then it'll get better but then the next time I'm pulling a hill it's bad again.
So the question is this... what could cause a misfire and be aggravated by excessive load (or possibly heat). Plugs are new. Cables are new. Coil-pack and igniter are original. Fuel pump is Evo IX. I'm leaning toward spark and not fuel cause I don't get any knock until after it starts breaking up and it seams like a lean condition would cause knock long before misfire. I'm also thinking it may be an alternator issue. Long exposure to heat could cause the alternator to run weak and lower the voltage at the igniter. Possible? Maybe.
Chime in if you have an idea...
