Battery relocation, need pics.
Brunoboy
San Bruno,CA Home of SFO
I had done it on 352/1000 but want to do it another way. I want pics of what you guys are doing to mount the wiring in the engine bay. What gauge wires are you using, and what ground points for the battery? Thanks
-shane
Brunoboy
Can you link me Shane? Lol I can't find it.
LIV4PSI
O-H-I-O
Check the members gallery, it's the second or third thread
Brunoboy
Thanks! I was looking through general and technical lol
Brunoboy
More curious about what fuse blocks and mounting people are using in the engine bay itself.
EMX5636
Bucks County, PA
I'll put up a pic in here of the front half. I'm using a gold plated ( /ubbthreads/images/graemlins/ooo.gif ) distribution block. I'm also using a stock DSM A/C Fuse box lid to cover the whole thing. No one realizes it's there. lol
Cherry Hill, NJ
here you go shane
start at the far left, that is where the battery cable is and the started cable
then the lower two are positive and the upper two are negative.
Brunoboy
Quoting EMX5636:
Yes please! It's be much appreciated. If you can and its mt too much trouble, take pics of the top and sides and bottom of you can so that I can picture it the best.
Shane I appreciate it! Is that the oem fuse box that's under the hood?
EMX5636
Bucks County, PA
Here's one with the cover on. The other 3 pics are being stupid in Photobucket. I'll add them when they work correctly.
EMX5636
Bucks County, PA
Finally! /ubbthreads/images/graemlins/banghead.gif Let me know if you need anything else. It's bolted down to the bracket where the hydraulic clutch line goes through. These are all hot wires. Large one goes from the battery. 1/0 gauge I think. Black/Red goes to the starter. Whites go to the fuse box. Small red goes to my Meth pump/solenoid.
Brunoboy
Thanks! So that block feeds your fuse block ?
Brunoboy
How come both your fuse boxes look different than mine?
Shane , is there another one I am missing?
Brunoboy
So how'd you make the one in your pic? It's a distribution box?
Cherry Hill, NJ
this is kinda what i have.
edit- with mine i broke the metal piece off the top, drilled a hole in the top for mounting and cut the tabs off, mounted it flat and it works great for me.
