shifting is still the same after new parts installed.. Please help
Fukenvr4
Houston, tx
its a 91 Galant VR4 with about 70,000 original miles and its 100% stock. The only issue that I have with the car before I changed the clutch is that i have to step on the clutch all the way to floor to change the gears. Heck , I thought it was time for a clutch change so i bought everything brand new, Mitsu oem clutch , New mitsu flywheel, Mitsu throw out bearing, Mitsu fluids, oem mitsu master and slave cylinder. After the install it got a little better but i still have to press the clutch pedal all the way down so that i can change gears. I've bled the slave and master and adjusted the master cylinder's piston nut but it seems that its not the issue here. What else should i be looking for?..Please help
newpoppop
Gibbstown, NJ
can that be put in the right position and welded??
CutlassJim
Manchester, NH
Don't you always put the clutch to the floor to shift? /ubbthreads/images/graemlins/dunno.gif
When you bled the clutch did you push the piston in before you cracked the bleeder at least once?
Or try pulling this shift pedal up after an actuation. If it comes up it needs to be rebuilt.
