Intermittent electrical issues
strokin4dr
Savannah, GA
I'm having a rather odd problem with a gvr4 that I picked up last summer. I spent the last couple of hours searching the board to see if anyone else has experienced this too, and while I found some similar issues they haven't helped me yet.
The problem involves the power door locks, the clock illumination (and possibly memory), and the windshield wiper switch. This is all I have noticed so far, there could be other things going on that have not shown themselves yet.
When I first got the car running and began to put some miles on it, I noticed that after setting the clock that it would be reset sometimes when I got back in the car, whether it be days or minutes later. Doesn't always happen; it's just random. I didn't notice the other problems at first so they may not be related to this at all.
Not that I have been driving the car more regularly, I noticed that the clock will randomly go dim sometimes while driving (during the day, headlights off). It will stay dim for a while and then return to a more normal appearance where its easy to read.
Well today I noticed that anytime the clock is dim, the power door locks will not work at all. No matter which door I try pulling the lock tab on. And also the low speed setting on the wipers won't work. Only the low speed, all the rest of the speeds work fine! WTF???
When the clock is illuminating normally everything works as it should; locks work, all wiper speeds work, etc. As soon as I notice its gone dim again none of the mentioned item will respond.
Anyone ever had an issue like this?? I've looked for anything abnormal. I did find a thread that mentioned looking at the radio harness for clock issues. I am going to start there and pull that apart soon to check it out. Like I said, I bought this car last summer and am slowing fixing all the little issues that the previous owner didn't point out so this could be something that has been going on for a while or a new problem that is just showing its head. Weird.
Any help is appreciated. Thanks.
-Ryan
G
zompton
Sounds like intermittent grounding issues.
