toslow
So I need some info or atleast some direction and some of the guys on this forum have more than impressed me with knowledge.
My stock block evo 8 at about 420 whp (mustang Dyno ) came apart about 2 years ago. Picked up a long block from awd motorsports and sent to machine shop locally to have je pistons and Manley rods installed. Lasted about 5 months at about 490 whp and spun a bearing. Removed the block and off to same local machine shop and replaced the crank and installed a set of GSC rods. This is the same machine shop I have used through multiple builds and the shop our Nissan dealership used on a regular basis. Put the car back together and strangely the car was difficult to go into 1st and reverse. Called shep and he said not irregular, adjust the pedal and see what happens. Good to go and he said I should be fine. Now my thought was that clutch was not fully engaging, guess I felt like it was crank walking. Within about 500 miles still in break in mileage before tune. It got worse and I felt like the engine was starting to make noise so I pulled it out. Trans got shipped to shep for inspection and proceeded to do build cause he said the input shaft was bent and had some chipped gears. So now to my issue. The block was taken to the machine shop, they kept giving me the run around and after 6 weeks they tell me they do not want to work on the block because I run nitrous through the engine and they would rather not work on it!!!!!!!! I have never ran nitrous period and would never run nitrous. I don't even know if there is an issue with the block but after all the money I've spent at this point I feel like its not worth rechecking it before I reinstall it. So I've been a tech all my life, I'm now a service manager at a dealer but I still have all my tools but I've never done all the measurements and actually built an engine. I've searched for classes at local college but they are through the day and does not fit my work schedule. Is there books or a website they may be able to help me. I just can believe I've spent all this money and I feel like I can't trust that side of this build.
