K-sport............camber?
presterone
brunswick maine
I have these coilovers that came with my car when I bought it. The front adjustable pillow ball mounts can only mount in a way that it adjusts caster and not camber. I thought that it would fit if I turned the mounts 90 degrees, but it will definately fit only one way. Unless I bored out the bolt holes in the strut tower it won't work, Has anybody had this problem? I heard if they were for a DSM that they could be turned 90 degrees and work but this is not the case.
presterone
brunswick maine
Nevermind found a thread through google, Looks like I have to drill a hole? o well
theevozero
Odessa, Texas
I use the k-sport pillow ball mounts with agx struts and it allows me to adjust camber only. Although, I did have to modify them to work. Sounds like you have it all figured out. Good luck!
presterone
brunswick maine
So what would they have other than spherical bearings? rubber ? I guess the pillowball mounts wouldn't be ideal for a daily driver.
