BISS screw gone.....
rdomeck
Indianapolis, In.
I knew it needed a new o-ring. I had to reset about every 1000 miles. Well it really loosened up on a couple hundred mile road trip yesterday and now I need a replacement. I have found a standard Galant in the local pull a part. Will a non turbo biss screw work?
citymunky
Chesapeake, VA
I don't why it wouldn't. Also you can Advance Auto Parts or whatever for the o-ring, they should have a box to metric single package o-rings.
rdomeck
Indianapolis, In.
Great, Thanks. I'll be heading to the yard soon.
donniekak
surprise az
Almost all of the 90's mitsu biss's are the same. Some are plastic, and some are metal, but they interchange.
rdomeck
Indianapolis, In.
Pulled one from a 93......Along with a mint set of headlights!
SCORE /ubbthreads/images/graemlins/applause.gif
rdomeck
Indianapolis, In.
I would imagine that would either go in well and stay there making it a bitch to remove later, or go in easy and blow out at the first sign of boost pressure?
Wizardawd
Franklin, NC
Quoting PreskitVR4:
You should carry a plastic valvestem cap around in your glovebox. It is the perfect size.
Why carry it in your glovebox? I have 4 on my rims.
And I think he means it as being a emergency hole filler if the BISS pops out. So your car isn't screaming at 4-5k rpm all the time. Stay out of boost until you limp home type of thing.
Wiz
