Number996
Thanks to Toybreaker's help, my Galant was ready. I put her on the ground and was letting her warm up before taking her out for the first time. Then, my friend bumped the ecu (was on passenger floor) and she died immidiately then there was a backfire and some electrical sounds like sparks from the engine bay.
Now, when she cranks there is no signal to the spark plugs. I know this because I had my friend hold a timig light while I cranked her; no flash.
At first, when I tried cranking her immidiately after she died, the stock boost gauge would light up when key was in on position but the CEL would not. After unplugging and replugging in the ecu (and bolting it up) the CEL will light up when key is in the ON position butthen goes off. If I crank her the CEL will go off and stay off.
When she was starting fine and idling the CEL would be on and stay on.
The only peculiar things to happen before this were; while pulling on thermostat wires to get ready to rewire the engine coolant temp sensor, there were some electrical spark like sounds from driver side front engine bay area, I couldn't make it happen again so I continued. Then, I heard some more of the same electrical sounds while using a multimeter to isolate the correct wires for coolant temp sensor. These were the same sounds that occured right after she just died in mid idle rigt after the backfire.
Ecu was also opened to inspect for damage. None that I could see.
All fuses good.
Please guys, i'm at my wits end. Thanks
All fuses good.
