Data logger connection help
James
Port richey Florida
Well since I've got the idle worked out, now I'll take the time and pick your brains about why my logger won't connect to the car....
Problem: serial connection error
Facts about my car:
-1990 galant GSX
-Dsm motor/trans swapped in
-1992 ECU swapped in
-don't know If wiring harness was swapped or stock on modified to work.
When I plug it all in and open the program and select all the values it would like it to read then select start... I get nothing. It cycles through the list of items to read at the bottom then pauses itself.
If I go into the options and go to "read codes" or however it's worded I get the serial error.
The port works, and by that I mean I can pull engin codes by using pins 1 and 12 with my buzzer
James
Port richey Florida
And just to maybe spark someone's memory about an obscure situation...
I read a while back, but I can't find it now, that someone had a similar issue, with a nt talon that had a turbo motor trans ECU swapped in like me... He couldn't get the car to connect with the pilot, he found out that the harness side of the o2 is different, he cut in the correct wiring for the ECU plug and it fixed his problem...
Can someone confirm or deny that NT o2 on the harness side and turbo o2 on the harness side are the same or different?
James
Port richey Florida
No luck here huh?
James
Port richey Florida
Ttt on this... I've been googling since I posted this and haven't come up with anything :/
jepherz
KC, Missouri
What are you using to connect with? Have you used this combo successfully in the past?
James
Port richey Florida
Let me see if I still have the pic, I'll edit with pics
I have not used it before but the user on here I purchased it from obviously claimed it works.
And I have no local Dsm crowd to help me with this.
jepherz
KC, Missouri
You aren't using any converter or null modem adapter on the palm to logger cable connection, are you? Did you buy the entire setup from one person?
James
Port richey Florida
Yea all from one person. It goes like this..
Palm pilot
Palm end of the cord1 to serial end of cord1
Serial end of cord2 to diagnostics port end of plug2
James
Port richey Florida
Like so.. If I go into check codes I get a "serial comm error" or something similar.
raptorWagon
Oak Harbor, WA
Those datalogger cables are picky about what adapters you use. With connecting to a laptop in the past, I found you will get the same comm error if you use a generic pos brand db9 to usb adapter (if it's not something like a keyspan, it's garbage), I wonder if it's the same for the db9 to Palm adapter.
James
Port richey Florida
That's mostly what I've read also, Tim. I wish I knew someone who had a working cable to test with! Buying a "name brand" cable seems doesn't seem like best option (money wise) as it may not even work, but perhaps my only option.
jepherz
KC, Missouri
Quoting raptorreed:
There's nothing simulating the serial signal in the setup pictured so it wouldn't have the same issues with the connector.
Only thing I can think is either the cable is bad, or it's wired up for a PC with the wrong gender. If this is the case, you can swap pins 2 and 3 by getting a null modem adapter. That'd be a pretty big goof when making that cable though...
James
Port richey Florida
Can you go into a little more detail there for me Jeff? Wires and electronics really just aren't my thing.
jepherz
KC, Missouri
The pins on a palm DB9 connector are reversed between PC and palm. Therefore, when you're using one or the other device, you'd have to switch pins 2 and 3 (transmit and receive) for the cable to work. However, they are also different genders, so it's probably not likely that this is the cause being that the gender of db9 on your cable is set up to hook into the Palm. If you know the diagnostics port is good, it really sounds like the only other thing you can try is start swapping out the cables for known working ones.
James
Port richey Florida
The pOrt works as far as I can use my buzzer to pull codes and It works to correctly set the idle. Are there other ways to test it?
