beefajita
Active member
So for many years now I have had a noise under deceleration at about 3000rpm that sounded like metal on metal bolts in a washing machine. Other people on this forum and other DSM forums have reported the same thing. Some turned out to be clutches, others were the "wob-wob" noise from a worn carrier bearing, and still others took all the suggestions from other users and reported that the noise still persists. I remember reading a post from one person that his car had been doing it for years and he simply drove around the noise by not engine breaking and kicking it into neutral when slowing down. I talked to Shep years ago (he built my tranny)and his over the phone diagnosis was an out of balance flywheel and pressure plate assembly. I too, like many others replaced carrier bearings, balanced my clutch assembly, balanced my aluminum driveshaft, changed motor mounts, ect. But the noise kept persisting.
Then, last week I noticed a spacer in the assembly diagram that goes in between the bracket for the intermediate shaft and the engine block. I had taken my transmission on and off dozens of times and I knew that no such spacers ever came with my car. It should be noted that previous owners of my car were horrible mechanics and I have spent years undoing the damage they have done; from rewiring the harness under the hood and under the dash because it was so hacked up, to finding grounds that had just been deleted, to replacing home depot hardware that was used in place of suspension bolts. It was no surprise to me that these spacers were missing. Without the spacers the intermediate shaft, or half shaft as I like to can it, sat cock-eyed coming out of the transmission, barley noticeable unless you line your eye up so you can compare the angle of the shaft with the angle the block and oil pan sit at, the shaft and edge of the block should be parallel. Without the spacers, the half shaft had a decreasing angle moving out to the CV joint, thus sat cock-eyed. The noise under decel turned out to be the half-shaft's bracket resonating against the engine block. I ordered all factory hardware for the intermediate shaft's bracket, and botta-boom-botta-bing, no more noise under decel.
Here is a picture of the spacer I speak of:
