i had recently bought a vr4 galant it had some issues not hitting boost what not. That problem was fixed (it was just a finger sizes hole in the charge piping) anyway. now under wot car bogs down a bit but when i slowly let out of it she starts taking off. I'm going to do another boost leak test and also look into the fuel pressure regulator and also inspect the turbo shaft to see if its any good as well as a compression test cause it did today after coming home from a 30 min cruise letting it sit for 10 min. started back up and it puffed white smoke(minimum). any advise on why it would bog like that. common sense would tell me its running rich and has to much fuel... yes? no?
thanks in advance,
dakota
thanks in advance,
dakota
