Where do the rear subframe washers go?
I took it apart too long ago and I forgot.
I've watched the boostx install and it tells me that the dimpled washers go in the mustache bar, but I don't see how that's right. The mustache bushings aren't recessed for them. Here's a pic:
Where do the other two sets go? It looks like I should have a third set? One bushing will be left to contact the underbody alone?
Thanks, I got it.
Anyone know the torque specs of the subframe pin? The pin that the subframe bolts to with the three mounting bolts, I couldn't find them anywhere.
Also wondering what rear mounting you guys are running with your struts. I have BC coils and they came with a washer I'm not sure how to include in the factory bolt/lock washer/washer combo. The factory bolt is rusty and in staying with replacing everything that's questionable, I plan to hit up JNZ for a bunch of hardware tomorrow. I'm talking about where the strut mounts to the spindle if you haven't already guessed.
nsin
monterey bay, ca.
That ring goes in first, then the A arm strut.
nsin
monterey bay, ca.
Yeah i did, exisiting bolts and washers. I was disapointed they didnt include camber bolts for the fronts. I used to my evo
When tightening the mustache bolts the bushings squeeze out. I can't get them to torque spec. Thoughts?
