Got a strange yet hopefully wonderful turbo need advice
so im not super familiar with MHI turbos and info i can find is very conflicting, so ill ask the experts.
Its a 20g for a subaru. it has the older Forced Performance stamp on it. it has a subaru flange right now. the number on the front cover are: 49179-54900
is there a hotside i can use on this to put on a DSM flange? its in perfect shape so im into it.
what do you think?
dsm10o0
San Jose CA
Im guessing its a td06? If so you can get a 16g turbine housing machined to fit the bigger td06 wheel
BluFalcon
Wichita, KS
Got a picture?
The bearing housings on Subaru MHI style turbos use different locations on the housing for water cooling. DSM/Mitsu housing use the top hole on the fore and aft side for water cooling. Subaru uses the top and bottom holes on one side with the other holes blocked off. I'm not sure which side of the Subaru bearing housing has the blocked off holes. If you weren't going to run water lines, then this isn't an issue. The alignment pin for the T/H is in the same position on the MHI style TD05 bearing housings, so a properly clearanced DSM/Mitsu T/H should fit and be aligned correctly. The comp cover would need to be re-clocked to whatever orientation you need for your setup.
BluFalcon
Wichita, KS
Also something else I forgot, The housing is tapped for a smaller diameter oil feed bolt, so you'll have to change over to a banjo bolt and fitting from a Subaru Oil Feed Line.
