Wheel bearing part number confirmation?
Rock auto claims this is the part number for the rear: (using amazon because you can't link rock)
That's not right though is it? We don't have the option to just swap the hubs out correct?
And here is what I have found for the front:
Go to top of post if nessissary.
Called today, $330, pricey, but I might have to do it.
Am I right in thinking that I can't just swap the hub? Now that I have it torn apart, I don't see why not?
donkeylips
Rochester, NY
Do you mean like how on some cars (such as the 2g dsm front hubs) you can just unbolt the entire hub assembly and replace it? Because you can't do that with any of ours. You'll have to remove the front knuckles and have the bearings pressed out. You should be able to remove the rear hubs and bearings on the car though.
Yeah, the rear is what I'm working on now, looks like I can just pull the hub with the bearings out and swap in a new one?
