CutlassJim
EDIT: I had the numbers all nice and lined up but the forum makes all my spaces 1 space and effs it all up so I threw a / in there. I like that effs doesn't set off the spell checker. /ubbthreads/images/graemlins/smile.gif
I'm building up a second head for the Galant and I'm going with an all Evo valvetrain again but this time I got all 9 valves so the exhaust ones are sodium filled. Just for the info I brought them to work and weighed everything versus their counterparts. The head is off a 96 so everything listed is 2G which I'm almost positive is the same as a 1G/GVR4.
The scale at work is accurate to 1 gram and I took the average of 3 for every piece measured.
DSM / Evo 9
Intake valve 55g / 55g
Exhaust valve 54g / 45g
Retainer 15g / 4g
Keeper (Set)(reusing stock) 2g / X
Spring 55g / 40g
Spring seat 4g / 4g
So for weight the springs need to control (Valve + retainer + keeper)
Intake 72g / 61g savings of 88g for set of 8
Exhaust 71g / 51g savings of 160g for set of 8
Total weight
Intake 131g / 105g savings of 208g for set of 8
Exhaust 130g / 95g savings of 280 for set of 8
Total weight savings of 488g or 1.08 lbs. Not much but combined with the higher rev ceiling of at least 7500 rpm (more like 8k) and the extra heat transfer of the sodium filled exhaust valves I think it's more than worth the $100 investment and more than enough for a sub 500hp head.
I am still in the process of porting and junk but will probably do another post on some of the tips and tricks I've come across scouring the net after I'm done.
While I was at it I also weighed the cam gears I had at my disposal.
1G 5 spoke 510g
2G 4 spoke 527g
2G intake (with ring) 707g
AEM adjustable 400g
Not sure if anyone cares about this stuff but there you go. I'm posting this on a few forums so the info is more accessible. Cheers!
DSM / Evo 9
Retainer 15g / 4g
Spring 55g / 40g
Spring seat 4g / 4g
Total weight
1G 5 spoke 510g
2G 4 spoke 527g
AEM adjustable 400g
