Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Windshield wiper problem will not turn off!
Leon_R
Galant VR-4 org Post #: 1052573 posted 02/20/12 10:07 AM     Remind Me!  Send Private Message   Edit Post
When I bought my GVR4, PO said that it had ETACS issue, which is why wiper motor was unplugged. When I finally got the car running and re-connected the wiper motor, everything seemed OK, I thought I got lucky with this problem. But about a week or two later, the wipers turned on and will NOT shut off! So, I too, started unplugging wiper motor.
I have tried another ETACS and wiper relay (on the firewall, right next to the wiper motor) without any luck.
Has anyone else experienced this type of wiper failure?
Leon
01 VehiCROSS
93 Eagle Summit TSI AWD [email protected] (4G63 transplant)
96 Mitsu Eclipse Spyder GSX
80 Triumph TR7 GST (4G63 transplant)
Posts: 211 | From: Chelmsford, MA | Member Since: 08/30/11 | IP: (199.46.198.232) | Report this post to a Moderator
MitchooO
knows how to break em
1972/2000
Galant VR-4 org Post #: 1052626 posted 02/20/12 05:33 PM     Remind Me!  Send Private Message   Edit Post
hopefully its not like my intermittant problem, Knock on wood its been good to me. Every once in a great while it would kick the dome light on like the door was open and the windshield wipers would run nonstop, so i pull the fuse to the wipers and shut the dome light to off on the switch. never traced it down but im not sure I want to. I'm guessing if you just have the wiper issue I would start with relays, Possibly one sticks when it feels like it.
If its not white. The owners not too Bright.
1972/2000- Wallet Nightmare with too big of a turbo
81 Toyota Starlet- long time search found for 500 bucks
93 Civic- Been in the family over 10 years. SOHC turbo beaten on everyday of its life
Posts: 350 | From: South Mountain, PA | Member Since: 10/10/07 | IP: (174.54.96.238) | Report this post to a Moderator
SouthCaliVR4
Gas Analyzer
825/2000
Galant VR-4 org Post #: 1052650 posted 02/20/12 09:01 PM     Remind Me!  Send Private Message   Edit Post
If the park position switch inside the wiper motor is bad they will just keep running as it has no idea where to stop, your wiper motor has power anytime the key is on. try another wiper motor before you get too deep into it.
How do you make a small fortune racing? Start with a very large one!!!
Posts: 984 | From: North county San Diego | Member Since: 07/31/10 | IP: (76.176.90.28) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1052802 posted 02/21/12 09:27 PM     Remind Me!  Send Private Message   Edit Post
Is the motor serviceable in this regard?
C53A 1 of the ~1500
Posts: 1604 | From: THE Ottawa | Member Since: 03/05/05 | IP: (99.240.172.18) | Report this post to a Moderator
Leon_R
Galant VR-4 org Post #: 1056734 posted 03/15/12 10:30 AM     Remind Me!  Send Private Message   Edit Post
Quoting SouthCaliVR4:
That seems to make sence, if wasn't for a fact that my motor is unplugged 95% of the time (whenever it isn't raining), but I can hear the relay clicking under the hood, trying to activate the wipers.
Unless it keeps doing it, waiting for a feedback from the motor "park" switch?
Leon
01 VehiCROSS
Posts: 211 | From: Chelmsford, MA | Member Since: 08/30/11 | IP: (198.228.192.141) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 1057027 posted 03/16/12 03:27 PM     Remind Me!  Send Private Message   Edit Post
Maybe your column switch is bad?
-Jeff
1881/2000
50/1000
Posts: 7871 | From: KC, Missouri | Member Since: 08/08/04 | IP: (159.140.254.100) | Report this post to a Moderator
Leon_R
Galant VR-4 org Post #: 1057056 posted 03/16/12 05:52 PM     Remind Me!  Send Private Message   Edit Post
Certainly seems plausible. Does anyone know which connector it is? I want to try disconnecting it.
Leon
01 VehiCROSS
Posts: 211 | From: Chelmsford, MA | Member Since: 08/30/11 | IP: (198.228.193.119) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 1057059 posted 03/16/12 06:09 PM     Remind Me!  Send Private Message   Edit Post
I believe it is the huge white connector with around 26-30 pins under the dash. If you take the column surround off it should be easy to trace the wires.
-Jeff
1881/2000
50/1000
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.108 seconds in which 0.09 seconds were spent on a total of 14 queries. Turbo powered.
