The 2.6 will have a horrible rod ratio and bad harmonics on top of need a trans to support that type of torque. I think the 2.4 build is the most displacement we'll ever need.
FYI:
Using an 88mm (stock 2.0L) crankshaft:
85mm bore = 1997cc
85.5mm bore = 2021
86mm bore = 2045
86.5mm bore = 2068
87mm bore = 2092
87.5mm bore = 2116
88mm bore = 2141
Rod Ratios: stock piston and 150mm rod = 1.70
stroker piston and 156mm rod = 1.77
stroker piston, 2.4 block, 162mm rod = 1.84
For a 92mm Magnus crankshaft:
85mm bore = 2088cc
85.5mm bore = 2113
86mm bore = 2138
86.5mm bore = 2163
87mm bore = 2188
87.5mm bore = 2213
88mm bore = 2238
Rod Ratios: stock piston, 148mm rod = 1.61
stroker piston, 154mm rod = 1.67
stroker piston, 2.4 block, 160mm rod = 1.74
For a 94mm Eagle crankshaft:
85mm bore = 2134cc
85.5mm bore = 2159
86mm bore = 2184
86.5mm bore = 2209
87mm bore = 2235
87.5mm bore = 2261
88mm bore = 2287
Rod Ratios: stock piston, 147mm rod = 1.56
stroker piston, 153mm rod = 1.63
stroker piston, 2.4 block, 159mm rod = 1.69
For a 97mm Crower crankshaft:
85mm bore = 2202cc
85.5mm bore = 2228
86mm bore = 2254
86.5mm bore = 2280
87mm bore = 2306
87.5mm bore = 2333
88mm bore = 2360
Rod Ratios: stock piston, 145.5mm rod = 1.5
stroker piston, 151.5mm rod = 1.56
stroker piston, 2.4 block, 157.5mm rod = 1.62
For a 100mm (stock 2.4L) crankshaft:
85mm bore = 2270cc
85.5mm bore = 2296
86mm bore = 2323
86.5mm bore = 2350
87mm bore = 2378
87.5mm bore = 2405
88mm bore = 2433
Rod Ratios: stock pistons, 144mm rod = 1.44
stroker pistons, 150mm rod = 1.50
stroker pistons, 2.4 block, 156mm rod = 1.56
For a 102mm Crower crankshaft:
85mm bore = 2315cc
85.5mm bore = 2342
86mm bore = 2370
86.5mm bore = 2397
87mm bore = 2425
87.5mm bore = 2453
88mm bore = 2481
Rod Ratios: stock piston, 143mm rod = 1.40
stroker piston, 149mm rod = 1.46
stroker piston, 2.4 block, 155mm rod = 1.52
For a 106mm Crower crankshaft:
Crower states the 106mm crank must be used in a 2.4L block, stock 2.4L bore is 86.5mm.
85mm bore = n/a
85.5mm bore = n/a
86mm bore = n/a
86.5mm bore = 2491cc
87mm bore = 2520
87.5mm bore = 2549
88mm bore = 2579
Rod Ratios: stock piston, 2.4 block, 147mm rod = 1.39
stroker piston, 2.4 block, 153mm rod = 1.44
