Don't know if you have looked at this already, but heres the vfaq click It lists common places to check. You can use a spray bottle with water and a dab of dish soap so you can see leaks that you are unable to hear.
A couple things to add to the vfaq. Prop the throttle body open, and make sure the engine is at top dead center. That will make sure all of the valves are closed. This way, you can pressure test all the way to the head.
