2g awd downpipe
marvinmadman
Lafayette, Louisiana
How does the 2g awd downpipes fit with a 1g catback on our galants? Any modifications like lengthening the cat back? I searched but honestly could find anything clear cut.
NickDromez
Berkeley, CA
you might be better off getting the DP an then getting custom tubing from an exhaust shop. it'll be cheaper unless you can get an excellt deal
marvinmadman
I already have a cheap 1g cat back, came with the car. Just need a dp as I don't have one at all.
OMFGeofffff
Burnsville, MN
One or few of the hangers are in different locations. And the muffler will have an angle to it like gsx_tc's muffler. Otherwise length should be right on with that combination. Well so I've read.
thedsmguy
Vancouver Washington
Seeing as how that I know the guy selling the DP /ubbthreads/images/graemlins/wink.gif. I suggest you put the catback that you have under your car and see if it mounts well, then, if that mounts up well and looks right buy the dp in question and worse case scenario is you have to add a little section or take a little section out.
marvinmadman
Too lazy for that Lmfao. I'll take the dp though.
Quoting thedsmguy:
