What Transmission Fluid/Gear oil do you use?
dsmkid
Denver, Co
Im planning on doing a flush today on the gvr4 I just got and just wondering what you all would suggest. What do you use and have good luck with? I am experiencing some 2nd gear grinds at high rpm and its hard to get into 2nd at 7k at the track. I know the culprit is probly not a fluid problem but hopefully it can help it a bit. Keep in mind I live in Colorado and we do get Cold winters, sub freezing. This will be what I use all this winter. Thanks in advance!
Brunoboy
San Bruno,CA Home of SFO
MT-90 x3 in the trans and Heavy Duty Shock Proof in the X-case and Rear Diff.
Launch
Texas
Only motul in my high tq trans, wax kills. shockproof in transfer and rear
Mitsubishi Diaqueen in the transmission and Redline Heavy Duty Shockproof.
Dark_Horse
Morrison, CO
Since you live in Colorado, I wouldn't run heavy shockproof in the winter. Heavy doesn't like temps below 45 degrees.
cupajoe
Cocoa, FL
Mitsubishi Diaqueen in the transmission and Heavy shockproof in Tcase/rear diff. But I'm going to switch my transmission fluid to MT-90(2/3) and MTL.(1/3)
BG syncro shift
75/90 seems to be a tried and true for the trans atleast
turbofonz
Granby, MA
I'd run straight MT90 for now.
When spring comes around and you start beating on it a little more toss in some shockproof for some...shock proofing.
You don't want to put shockproof in the transmission. The syncros don't like it.
shockproof is best in the T-case and rear diff right?
Yes, 100%. But if you drive in cold weather, may want to run a bit thinner when temps drop below 40.
glad i'll be in one of the hottest dam places, Houston Tx.
boostedinaz
Scottsdale, AZ
