Vacuum Line Routing?
Just finishing up on my head install and not sure where to route a couple of my vacuum lines, I've seen the voodoo diagrams but this is a little different.
For the bov line, can I just connect the line from the bov to the ic pipe right next to it? I'm not sure if the vacuum source would matter if it before the throttle body or after, sourcing it to the intake manifold.
Also, on my other dsm's I've always just blocked off the ports on the throttle body but on one of the diagrams it shows you can use the "p" port as a source, it shows to a boost gauge. I just want to confirm if it'll work and read correctly. Can the other throttle body ports be used as a vacuum source or should I just block the rest of them off?
broxma
San Antonio Tx
It matters.
The vacuum to move the BOV comes from the vacuum in the manifold. There are really only two vacuum lines needed on the car. One to the BOV and one to the FPR. There is a smaller port on the right front of the manifold and a larger one, on the front left. Those are the ones I use. You can T the right side smaller port for the boost gauge.
/brox
What about the fuel pressure solenoid? It won't get messed up or anything? And for the boost gauge I can't use the "p" port on the throttle body?
MuffinMan7580
Fort Bragg, NC
The fuel pressure solenoid is not needed to have the car run. I believe it has something to do with super cold starts.
broxma
San Antonio Tx
I mentioned the Fuel Pressure solenoid (FPR). You actually don't need a line to it to start or idle the car. The boost to the FPR is what increases the fuel pressure with boost, nothing more. You can run it directly to the manifold.
/brox
