2.5" o2 housing install troubles
Just got a 2.5" o2 housing, probably an ebay brand or megan, got it from a local, and I can't get the o2 sensor to fit into the housing because it keeps hitting the waterpipe. I can't even thread it in. I know for the stock housings the sensor bung is further down and out of the way.
Am I stuck with putting the stock housing back on? I have a 2g housing just laying around, is that any better than the vr4's housing?
TIA
WaRrIoRs16
Ferndale, WA
It would be a pain in the butt to swap sensors out, but did you try putting the sensor in the housing, then bolting the housing up? I have a megan racing tubular o2 housing and I haven't had any clearance issues. I can get a o2 socket on my o2 sensor when its all bolted down.
boostedinaz
Scottsdale, AZ
That's what I was thinking. If it still doesn't fit then you would need to have the bung rewelded in a different position or get a different O2 housing.
Quoting WaRrIoRs16:
Yup, I tried that... damnit... I guess I'll put my spare 2g housing on for the time being. At least I got it for cheap(20 bucks), I'm pretty sure the bung just needs to be repositioned, the angle its at causes the sensor to hit the water pipe... Well, I'll just have to play w/ it later on.
spooling92vr4
long island, NY
how much is it hitting the water pipe? its kind of ghetto, but it wont hurt anything if you dent the water pipe a smidge.
FWIW:
2G housings do flow better.
Quoting spooling92vr4:
I thought about it, but I'm just gonna take it somewhere to get the bung rewelded.
Would the tubular housing be significantly better than the 2g housing?
Yes, pending if it's built right, but it should. Evo3's flow better than 2G, but have a slightly different exhaust angle on the outlet.
thedsmguy
Vancouver Washington
You could ghetto fab it a bit by trying to bend the o2 housing, take a BFH and hit it on the edge of the o2 bung and see if you can just lightly change the angle that the o2 would stick out.
boostedinaz
Scottsdale, AZ
Nothing against anyone but please don't do any beat to fit paint to match type "fixes". They always back fire somehow and end up costing more time or money.
Haha yeah, hitting the sensor definitely wouldn't work. I'm just going to cover the hole and drill and weld a new bung, still have the one that came with my aem wideband.
You can get a 14x 1.5 drain plug bolt to seal your old bung hole...
hehe
Xcelerate
Active member
North jersey
If its an ebay brand you better off using the 2g housing. First it flows better. Second the exhaust manifold and the o2 housing is the hotest part or the exhaust and with the poor quality on that ebay housing, you will still end up replacing it with something better. So think about it before putting more time and money on it and see if its worthed
SSGdave
San Diego, CA
Ok, I experienced this during the rebuild of 1855/2000.
I have a Punishment Racing 2.5in 02 housing. Same issue with sensor fitment.
All I did was Dimple the water pipe with a small hammer and tadaa it fits.
Actualy I mounted it all on an engine I had laying around and moded the water pipe off the car. Painted it and installed the water pipe and complete turbo onto 1855, then mounted the heat shields and done deal. Can't see a thing eather when you look at the engine. Totally stealth.
