brake pedal switch problem
Tre3zy
South San Francisco, CA
ok so i just recently started to have problems with my brake pedal switch... it keeps blowing out the 15A(STOP) fuse from under the dash board... i changed the pedal switch to a brand new one and its still doing the same thing... any idea's on where i should check next???
Tre3zy
Any body got the wiring diagram for it???
Brunoboy
San Bruno,CA Home of SFO
did you hook up any other electrical like gauges or anything to that power wire?
Tre3zy
Nope... Seems to be a grounding issue... Need to chase where the problem is... So i need a wiring diagram
Brunoboy
oh ok, good luck, i gotta track this damn foglight bs down lol
This may be a dumb question, but why are you certain that it is the brake switch? Reason i ask is that iirc the bulbs are powered off of that fuse under a stopping condition. Bulb failures are a major source of frustation for me with two of my DD's, and because one of them has a "light control module", I get stupid readouts on the dash that vary from "right brake light open circuit" to "turn signal circuit shorted to ground", and it has always been a damn bulb. In one of my DD's I have resorted to putting direct replacement LED bulbs in at $20 a pair because they last a year instead of 2 months.
