Monster cams
Galantvr41062
plymouth, MN
I run Crower 288's, there are a few cam sets that are bigger, like the Comp 101400's are a little bigger. What is your setup or plans for a setup?
~John
dmj
orlando FL
No mention of anything that says monster. Kelford is a reputable manufacturer.
FlyingEagle
THE Ottawa
Kelfords, they are good. You need to build your motor and turbo around something this specific.
Should use a small "M" in "monster".
Launch
Texas
Fp 11 ex cam. As the wookie put it 'The johnny wad of engine cams"
Brianawd
Portland OR,
Don't just pick your cam based on how big it is. Figure out what you want the car to do. Street car,track car, little of both. also what turbo your going to use. Do you want a turbo that has good bottom and mid range power. Do you want a car that is all top end and pulls like a fright train from 6k up. Or do you want a turbo that has a nice mix of both mid and top end(more street)power. Pick your turbo and engine build and then read up on cams and see what best fits your build and goals.
P.S also don't for get intake and exhaust manifolds. They play into the mix
alansupra94
Wayne,NJ
What he said. Just build you setup based on how you like it and find camshafts that compliment that.
