power locks and wipers don't work
since I got my vr4 the power locks and intermediate wipers don't work. I replaced the gold relay on the firewall thinking that would fix my wiper problem but that didn't work. all of my fuses are good. I did some searching and some say check the etacs, but wouldn't the windows and everything else related to that not work aswell? I also heard there is a relay under the steering column for the locks but I can't figure out which one it is, does anybody have a pic of that relay.
any other ideas on what it could be?
thanks,
ed
My power locks don't work either, I wonder if it is that relay under the dash, if I remember correctly it's the only one with 7 pins.
strokin4dr
Savannah, GA
Most likely a bad ETACS box if all of your wiring and fuses check out good. It is located under the dash on the driver's side, above the fuse box. I think it has "2.0T" printed on its label.
would a 1g dsm ETACS be compatible with our cars? and where is it located on one?
Check to see if it's the relay before you go replacing etacs
Wizardawd
Franklin, NC
Also check the fuses. I had no radio, no dome lights, no dash lights and the locks didn't work. Thought it may be a bad ETACS, turned out to be a blown dome light fuse.
Wiz
