FS: 92 Belize Green Galant VR-4 MD $3500
Hello everyone, I am deploying to Kuwait in Sept and I can only store two vehicles when I leave, I have four, so the galant gets the short end of the stick. The car has 192,000 on it, the engine has about 5,600 on it and I'm still driving it. The car has a built engine, head was done by cornbread racing and the block was done by the DSM graveyard, it has ARP head studs and bolts, Ferra valves, wiseco pistons, JE rods, FP2 Cams, ACT clutch, Fidanza flywheel, exhaust from the down-pipe back and a 16g turbo. I don't have the paperwork for the engine, I feel that the price reflex that. The injectors and ECU are stock so the car is still running on the stock tune, but it does have a SAFC 2 hooked up and connected in the car. Some parts that I do have that are not installed are GM MAF with translator, extra computer for DSMlink, four bolt diff with axles and cups, EVO 8 inter-cooler, another brand new 16g turbo, and some other things. The car has the five lug swap already done and EVO 8 enkei rims painted black with brand new tires. I ordered the stock tire size for an EVO for the rims and they seem to be a little too big.
I am asking 3500 for the car with all of the parts that I have for the car. There is a power steering leak somewhere on the car, I think that it is somewhere in the front. The paint is fading, and the rear seat has a rip on the top. My number is 631-681-7841, my name is James and texting is the best way to get in touch with me because I cannot answer my phone at all times. If you have any questions let me know.
No, the first picture was when it was four lug, the black evo rims are after I swapped it over to five.
mcl0vin
cape coral, fl
can you post some more pics of the inside of the car. and maybe under the hood.... is there any rust on the car? dose it have AC and dose it work?how far and how often do you drive the car?
thanks
Interior is good except for the tear in the top of the rear seat. AC worked before the engine swap, but I haven't charged the system to see if it still does. Car has slight surface rust in some areas. I still drive the car to work everyday which is about two miles bad and forth. Also forgot to add that the car now has a new radiator.
highspeed
AFCRAPISTAN
Nice ride
Do you have any proof of engine mods? Pix of engine mods? Reason I ask is because it looks pretty stock under the hood for having a completely built motor.
BTW I am in Afghanistan right now, got the cash in hand(well in the bank) if it all checks out, I only have a few more months and I am done. LMK thanks
Here is a picture of the engine new, with new radiator.
Here is a picture of the new turbo and lines.
Tried to get a picture of the cams, I will have to put the cover this weekend and take some pics,
New studs and gasket
And the cam gears.
MMorgan
Haymarket, VA
Come on, there is only one real Ft Meade and thats the one in MD with DISA and NSA.... bump
Belize green VR4's are soooo sexy
talontyme
Portsmouth,VA.
Another score for the hampton roads gvr4 guys car went to a great home and will be well taken care of.
