Vman911
Seeing if there might be intrest in my ride. I hate to part with it but I'm thinking about a new ride.
Asking 7K. Its a very clean and nice VR4.
Car has 126K. 450 miles so far with new motor. 4wheel Steering still intact. Cruise works, Needs tunning. DSM Link V3 included with car.
Engine:
Weisco 9.0:1 pistons, Eagle rods, Bored .40 over. ACL race main and rod bearings. Arp Mains. New oil pump w/gears,Water pump,Oil pan, Brand New FPgreen Turbo, DNP Manifold w/ matching O2 housing and 38mm Tail wastegate. B.S. kit, New A/C compressor (no freon in it) All factory gaskets. All new bolts, New timing cover. 6an fuel feed line w/micron filter. 255LPH Fuel pump, 780 PTE injectors, Aeromotive FPR. Clear Timing cover, Custom Clear Coil on Plug setup. Alumnium Radiator, Mistomoto 14" slim fan. 7 bar AEM map sensor, Power core FMIC with 2.5" piping, Tial (knock off) BOV, Alumn Oil catch car. Polished VC (has expoxyed crack, very small) Evo8 Maf. 62.5mm throttle body, Valvetrain:
272 regrind cams, OBX cam gears, Evo8 springs and retainers, 3G lifters, 1.6MM Cometic Head gasket, Alumnium Intake, 60MM Throttle body. ARP head studs
Exterior:
93 Headlights with 8K HID's. 17" Gold Axis rims w/ 1/2" spacers, HR 1" drop springs, Kyb struts, New tires 4K miles ago. Paint I give a 7/10. 2 dents in trunk lid, little ripple in roof and some peeling of paint around some door handles and a fender. 3" custom Exhaust with high flow cat. Tinted windows. power folding mirrors
Drivetrain:
Act chromoly Flywheel (11lbs). 6 puck sprung Clutch with 2100 lb plate. New yoke on Drive shaft (no more leak, yea) 3000GT front brakes w/12.5" cross drilled and slotted rotors. Hps rear pads on stock cross drilled and slotted rotors. 4 Bolt LSD rear end. Green Poloy rear subframe bushings.
Rebuilt trans Evo3 HD Input shaft, Evo3 First gear (45 MPH at redline) Dual 2nd gear set up. Reused 3,4,5,rev. (3rd grinds a little at 8K rpm)
Interior:
White face guages, HKS turbo timer, 89 lower dash, Autometer Pro comp Ultra lite Guages, Boost, Oil Pressure, Water Temp, Wideband. Evo8 Steering Wheel, Evo 8 Seats Front and rear. Sony Cd with upgraded speakers. Green leds under dash. New floor matts, Clean Carpet 7/10. Short shifter.
I know there's more to it, may add more detials as they come.
Upgraded Key fob and dash badge w/ orignal dash badge. Orignal Window Sticker, first 35K of service records. Orignal seats included.
I got a ton of Build pics and other pics of this car transition to where it is now. I have owned it for 3yrs now and got it as a shell. Will take offers over 9K
Thanks Vinman
Engine:
Exterior:
Drivetrain:
Interior:
Thanks Vinman
