FS: 1992 Belize Green GVR-4 (476/1000) Mpls/St. Paul area, MN - $2250 - SOLD
Status
Not open for further replies.
After 7 great years it is time to sell my GVR-4 and I'm giving galantvr4.org members the first crack. If it isn't sold by 10/7/2010, it will be going on craigslist. First, the vitals:
VIN: JA3CX56U6NZ012073
~239,800 Miles
Moon Roof
Mostly stock
Runs well (Just took a 500 mile trip, 25 mpg with no problems)
Records back to November, 1995 (23K miles)
Transmission, transfer case & rear dif fluid changed every 30K
Timing belt changed at least every 60K
MN title in hand, clean and clear
$2250
email: trv2 at juno.com
The history:
TX/CO car (no salt) until 9/2000 (67,000 miles) when purchased by previous owner and brought to MN.
Ziebart rust protection 8/2001 (87,000 miles) including spraying inside doors and underbody coating.
Previous owner installed 2.5" turbo-back exhaust, Supra fuel pump, K&N filter, Blitz Dual Turbo Timer and removed boost control solenoid restrictor.
I purchased in August, 2003 (125,000 miles) and has been my daily driver with no further modifications since then.
Condition:
Very clean body; A little rust starting around center spoiler support, along edge of trunk lid & some rock chips on grill/hood.
Door ding/scratches on front & rear driver-side doors & rear qtr panel (see pics)
Clear coat pealing on spoiler & small baseball size spot on passenger rear qtr panel
Underbody very clean for a MN car
Tires @205K (plenty of good even tread left), timing belt @208K, Trans/xfer case/rear dif fluid @216K
Transmission shifts well except when stopped engine needs be to be idled down to prevent grinding into reverse & sometimes 1st.
Turbo spools well and car still pulls hard.
Engine burns around 2 quarts/3,000 miles (most noticeable when idling in traffic)
Cruise, 4WS, moonroof, power windows all work.
Leather in good shape; no tears or pulled seams except some wear on drivers side bolster (see pic)
A/C converted to R134A but currently not functioning.
No ABS (front wheel speed sensor went bad & I never thought much of the ABS on the VR-4 so I pulled the fuse)
Passenger side fog light is cracked (still works)
Needs new front struts
Exhaust manifold, downpipe, cat & muffler are all solid but there are some leaks in the piping.
If it looks like I missed something important, let me know.
MellowVR4
Milwaukee, Wi
all i gotta do is get rid of my car then i will be able to fly over their and drive it home /ubbthreads/images/graemlins/banghead.gif that is if u still have it by then.
4orced4door
Moderator
Raleigh, NC
This looks like a great deal. If you were in FL I couldn't pass it up...
Thanks for the comments. Hopefully someone from the board will jump on it. I put it up on craigslist last night and I'll have a hard time letting it go to anything but a very good home, but anyone holding the right amount of cash can be pretty persuasive.
Just got back from the DMV to transfer the title. Sold to a local guy who's building a 96 Eclipse GSX and wanted a GVR-4 for a daily driver.
Status
