This car is 100%street legal and has a clear NC title.
1991 VR4 seam welded with a tight multi point cage built by Sky-Tek ... Fully RA and Nasa compliant
2800lbs rally ready
Fresh (3 races) 2.0L motor with 5 angle valve job, Weisco 9:1 pistons, balanced crank, Eagle rods, No balance shafts, Mitsubishi head gasket, High strength head studs etc...
Fully balanced and blueprinted with 3 rallies on her...
380hp @ 360tq @18psi on 100oct gas with NO restrictor
320hp and 350tq with 34mm restrictor
Evo 3 Turbo and Manifold
580CC injectors
Trans rebuilt 4 events ago by TRE with double syncros, steel shift forks and a KAAZ lsd
PE-LTD stand alone ECU
Full bearing mounted suspension with fabbed arms in the rear as the 4WS was removed.
3/16 6061 skid plate by TAD
Hotbits double adjustable suspension with camber plates
15 Gallon ATL fuel cell with Bosch pump with adjustable req
Brakes are new mitsu units in the front and rebult calipers in the rear with 3 event on them
Dual tilton masters with balance bar
New Momo Safari halo seats and OMP FIA 6 point belts with 4 years remaining.
Front mount intercooler
highflow spal fans
Sparco steering wheel
Brantz rally computer
Peltor intercom
Map light
spill kit
light pod with 4 hella 4000's
Aluminum radiator
Plumbed in fire system
FIA master switch
FIA window film
Life hammers
All safety gear inc first aid kit, spill kit, tow rope
jack etc...
The car comes with a large spares package that includes many control arms, front and rear subframes, rear diff, drive shafts, computers,trans, transfer case, belts, hoses, shocks, 4 techno mag wheels, 3 kosei wheels,6 Braid Acropolis wheels (4 used once and 2 brand new) 9 x almost new michelin med compound rally tires (all mounted and balanced), 4 x Evo tarmac wheels, radiator and fans, trailing arms, brake calipers, pads, Rotors etc... Also 6 Michelins with very little wear and 6 Hankooks with about 70% left on them...
Rally America log book.
The car has been prepped and is ready for the next event with new fluids.
This car has never had any real damage since building and as well as running great, it also looks great and has been fully power washed top and bottom since the last event.
$11,900.00 located in Raleigh, NC
Call Doug on 919 219 9470 or [email protected]
Located in Raleigh, NC
2800lbs rally ready
580CC injectors
highflow spal fans
Peltor intercom
Map light
spill kit
Aluminum radiator
FIA master switch
FIA window film
Life hammers
jack etc...
