FS: #458/1000 1992 Summit White, IL, $2200 - SOLD
GVR4458
Illinois (Chicago suburbs)
SOLD!!!!
It's time for me to decide what to do with the car. I don't have time to work on it and it's taking up space.
I bought this car from my brother in 1999 (he was the original owner) with about 70k on the odometer. It now has about 180k. I have put a lot of work into making this a great daily driver. It handled and rode very well, spooled quickly, and was a great car to drive. Last year, the head gasket failed (during a test drive no less) and it has sat in my driveway waiting for me to make time for it. It isn't going to happen, so I'd rather sell it and have someone repair and use it.
It was in an accident several years ago and the work on the quarter panel was far from decent. The doors were also replaced and the crappy paint is peeling, showing the green door skkins. Other than that, the body is in decent shape.
Asking $2200 OBO
#458/1000
Summit White
Located in FAR NW Chicago suburbs (Algonquin, 60102)
180,000 miles
Stock engine with 180,000 miles on it
Tranny
ACT 2600
JUN Chromoly flywheel
Rebuilt Tranny but third seems a bit tricky at high revs/fast shifting
New Clutch master cyliner
New clutch slave cylinder
SS clutch line
Mofugas Short shifter with leather boot
Intake/Fuel
16G ported
3" SS, Mandrel Turbo-back
Intake in stock location
"Improved" flow intake pipe (I think it was an AMS special)
Walboro 255
Nippo Denso 660 injectors
AMS FMIC
264 cams
Suspension/Brakes
KYB GR2's
Whiteline Lowering Springs
Whiteline 22mm Front sway bar
Whiteline 24mm rear sway bar
Whiteline fron castor bushings
New swaybar end links
New Whiteline endlink bushings
New Whiteline control arm bushings
Goodrich Stainless Steel Brake lines
Wheels and Tires
Dunlop SP2 Winter Sports (1 needs replacing) on OZ 16"
Goodrich Gforce on GAB 16"
18" on Revolution knock offs
Other
New hood
Rebuilt ECU with logger cable
S-AFC
Palm III
Under radio DIN with:
Phantom boost guage
Phantom Water temp guage (hooked to the stock location on the cluster)
Phantom Oil pressure guage
Black valve cover
Black intake manifold (not installed)
SS Exhaust manifold cover
Manual boost controller
Unorthodox Racing Underdrive pulley
Driver side under-dash pocket (AFC mounted in there)
There was some decent undercoating sprayed on the car. there are only a few bad spot under the car.
NEEDS
Head gasket (a wise person will replace the water pump, timing belt, etc)
New rear quarter panel
"Oh Crap" handle for front passenger (parts are here, but it isn't in)
Small clips that hold grill in place (missing a few of them)
I think that a head gasket, water pump, intake and exhaust gaskets are all less than $500. A new quarter panel is about $700 installed and painted. The price seems fair. Any takers?
Car (rack is gone)
Bad quarter panel door jam
Crappy Passenger Door bottom (both pasenger doors were replaced and poorly painted)
Bad Quarter Panel (straight on the outside, just crappy inside)
Inside
Engine1
Engine2
Under1
Probably the worst spot for rust:
Under2
More to come later. The hood is sort of frozen shut, so no engine pics yet. It's dirty but it wasn't overly rusty when it got parked.
atc250r
Orange County, NY
Please fix the title so the thread doesn't get removed.
GVR4458
Some pictures have been added. It's under about 5 inches of snow, so they aren't the best. No under car shots until some of the snow melts and I have more time to mess around. Engine pictures will also requires some meltage...
EH
how bad is the head gasket, is it leaking oil, or burning coolant? does it have to be towed?
GVR4458
Definitely a tow or you can fix it in my driveway...It ran great right up to the point where it blew up. It limped about 1/4 mile to an exit, so it could drive up a flat bed.
