FS/FT 1989 Turbo Mirage, Allentown Pa, $6300... SOLD..
Factory 1989 turbo mirage, think im the third owner. Car has about 110k on it, if that.
Shell is pretty much mint minus a tiny bit of cancer starting on the corner of rear wheel wells. Has been the same since i got it about 7 years ago. Always been garaged since ive owned it.
Engine:
Stock bottom end with all new gaskets and timing belt
Stage 2 head job, ported with ss valves, new lifters
new tps and isc
vpc-gcc
b/s removed
90 oil cooler setup with stainless lines
stainless o2
greddy profec b
greddy turbo timer
greddy boost and egt
evo mani with tial gate
upper stainless piping with tial bov
spearco intercooler
bosch fuel pump
AGP L2 turbo
3 inch turbo back exhaust, has a slight leak
90 eprom ecu with keydiver chip
Drivetrain:
km210
Kaaz diff
3/4 steel shift fork
new shifter cables
2600 act pp
street disk
newer m/c and slave
Other things:
8pt chromoly cage
crow 5pt harnesses
Agx's with ground control, stiff spring rate
three speed scatter shield
weld draglites with m/h slicks
DP wheels with new yoko 225/45/16 tires
gvr4 knuckles and hubs with 2 piston calipers, did new tie rods and alignment
ss brake lines along with clutch line
no a/c or p/s, heater core has a crack so no heat
new ignition switch
new front wheel bearings
new front wheel studs
Some extras that come with the car.
89 turbo harness
axles
heater core
2 piston calipers
Sure im missing things but this is the list for now. Looking to get $7500 for everything.
Here are some pictures, the engine bay shot is kinda old but you get the idea. I will be updating the pictures once the rain stops and i get a chance to clean her up.
Link to some progress pictures, click
Willing to trade for a very clean gvr4.
Was this Nate's old car?
Nope.. I got it off this local guy who bought it from the original owner.
Thanks.
Nate
Worcester, Pa
Sorry to see you let it go, G-dawg.
A very clean car, done right. Any buyer will be happy.
And although NOT my old car, those are probably my old wheels and slicks. :)
G
zompton
Looks nice, a cyborg front bumper would like sweet on it.
IF I HAD THE MONEY I WOULD BUY THIS!!!!!!!!!! /ubbthreads/images/graemlins/worthy.gif NICE CAR!!!
