Phone Number: 646 894 6254
Hello I am selling my Galant VR-4 as I dont have much time for it as I used to. I am currently unemplolyed now and have to focus more on getting a new job to support myself then play with the car. Body has 115k miles and the motor has around 750 miles on it. I might forget to mention one or two mods but I will list it as best as I can from what I can remember right now. The car still has working 4WS, AC, Cruise Control, PS, etc.
I might be interested in some trades aswell.
EDIT!!: Forgot to mention the car has no rust problems on the chassis and under the car. Only one small spec under the pass taillight on the trunk. (Look at the pic, its miniscule at best).
The good:
Block: Showdown Motorsports Shortblock
6 bolt block
Manley I beam rods
Manley pistons 8.5:1 cr
Hot Tanked
Line Bored
Decked
Balanced to 10k+ rpm
Blueprinted
Clevite bearings
New oil pump
Balance shafts removed
All new seals and gaskets
ARP main studs
Head:
Revised lifters
280/280 BC Cams
Crower springs
Crower titanum retainers
Magnus Sheetmetal Intake Manifold
Magnus intake gasket
ARP head studs
Drivetrain:
ACT 2600 clutch
Fidanza flywheel
Stainless clutch line
Rebuilt transfercase via transfercase recall kit
New axles
3 bolt LSD rear
TEL shifter
Turbo:
Evo III ex. manifold
Forced Performance TD06 20G Turbo
Victory Performance SS O2 housing
2.5in. exhaust
2.5in. Test pipe
Tial 40mm wastegate
Tial BOV
FMIC - 12×24x3.5 bar & plate core
2.5in. IC piping
Engine management:
DSM Link v2.5
GM 3″ MAF
MAF-T Translator
950cc injectors
Rewired Walbro 255
Water/Meth activated @ 8psi
BoostX Coil On Plug setup
Autometer 30psi boost guage
Greddy EGT gauge (not hooked up)
Battery relocated to rear
HKS electronic boost controller
Greddy turbo timer
PLX M-300 WB02
Suspension:
Ground Control adjustable coilovers
KYB AGX adjustable struts
Energy Suspension
Whiteline swaybars
Whiteline front/ rear strutbars
Powerslot front rotors
Powerslot drilled rear rotors
OEM Roof racks /w keys.
The bad:
Slight leak from oil pan. Doesnt drip, just leaves a slight soot on the side of the pan.
Radio gets flaky sometimes, the face is probably going out.
Rear driver side rotor makes a slight squeal when turning left.
Clear coat on wing is coming off.
Some paint fade is present on the roof.
The good:
6 bolt block
Manley I beam rods
Hot Tanked
Line Bored
Decked
Blueprinted
Clevite bearings
New oil pump
ARP main studs
Head:
Revised lifters
280/280 BC Cams
Crower springs
ARP head studs
Drivetrain:
ACT 2600 clutch
Fidanza flywheel
New axles
3 bolt LSD rear
TEL shifter
Turbo:
2.5in. exhaust
2.5in. Test pipe
Tial 40mm wastegate
Tial BOV
2.5in. IC piping
Engine management:
DSM Link v2.5
GM 3″ MAF
MAF-T Translator
950cc injectors
Rewired Walbro 255
Greddy turbo timer
PLX M-300 WB02
Suspension:
Energy Suspension
Whiteline swaybars
The bad:
