Galant VR-4 Forums » Marketplace » Cars For Sale » FEELER: 2000 Celica GTS located in Indiana, $7,500
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1248268 posted 02/03/20 04:06 PM     Remind Me!  Send Private Message   Edit Post
Tentatively available spring with interest. I was going to wait a year, but I thought I'd check and see if anyone was interested.
The important: 137K miles
Lift works with revised lift bolts.
Engine and exhaust is stock. It has a K&N drop in.
The really good.
2500lb car, very smooth transmission, drives fantastic.
Suspension is TEIN H springs (mild drop) and KYB shocks, ST rear sway bar
The rear sway bar greatly reduced under steer, reduced body roll, and improved traction off the line. This one part was equally as important as the springs and shocks and completed the transformation on how the car drives.
Power stop brakes on all corners (stops very well)
Stock, the suspension was too high and soft, but fixed, these cars are highly underrated.
Leather is in great shape. No tears or rips.
Two brand new set of tires: Both 205-50-16
Pilot Sport A/S 3+ on Enkei wheels
Winterforce 2 with studs on stock wheels
It's winter, she's not detailed.
The bad:
Needs door actuators.
Driver floor mat is in bad shape
Stock wheels are in rough shape and could use a repaint.
$7500 obo
Edited by gvr4ever (02/05/20 06:55 AM)
Posts: 5932 | From: central Indiana | Member Since: 08/06/02 | IP: (199.168.78.42) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1248269 posted 02/03/20 04:07 PM     Remind Me!  Send Private Message   Edit Post
1992 Nile black w/sunroof
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1248271 posted 02/03/20 05:19 PM     Remind Me!  Send Private Message   Edit Post
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1248272 posted 02/03/20 05:57 PM     Remind Me!  Send Private Message   Edit Post
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1248273 posted 02/03/20 05:57 PM     Remind Me!  Send Private Message   Edit Post
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1248282 posted 02/04/20 05:54 PM     Remind Me!  Send Private Message   Edit Post
A few things about the 2000 Celica GTS. It had the most aggressive ECU. The lift point is between 6000 and 6200. Mine seems to be exactly 6100 by the tach. Fuel cut is higher than following years at 8350. 2000 also had a shorter shift gate. This ended up with people missing a gear and blowing up the engine, but if you learn the car first, it won't be a problem. It just has a shorter H gate.
I've had the car for 10 years and I'm just ready to move on. It's been the most reliable car I've had long term.
In 10 years, it's had 4 issues. A bad battery terminal that was replaced by a Toyota part, the air meter needed to be cleaned, a wheel bearing was recently replaced, and I had a broken lift bolt fixed. Both have the revised part and shouldn't be a issue ever again, but they are easy to replace before they break. Just involves taking the valve cover off. Something to do every 60-80K?!?!? They are cheap parts.
I hope the right owner finds this.
Edited by gvr4ever (02/05/20 06:50 AM)
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1248436 posted 03/10/20 05:42 PM     Remind Me!  Send Private Message   Edit Post
Probably going to wait a little longer.
A very strong contender for a replacement is a Elantra GT N line, but the 2021 refresh looks to be worth the wait.
If anyone is actually interested in the Celica, please PM me. The asking price will be a grand less in a year. I just have about 1400 buxs in tires and mounting/balancing. Once worn, I won't be asking as much.
Edited by gvr4ever (03/11/20 08:31 AM)
1 registered and 5 anonymous users are browsing this forum.
Generated in 0.133 seconds in which 0.102 seconds were spent on a total of 14 queries. Turbo powered.
