FS: 91 galant vr4 $7000 1439/2000
Tim
New member
Maryland
1991 Mitsubishi Galant VR-4 vr4
Engine machine work done here by Goza machine, head decked, block decked, hot tanked,
bored .020 over, supertech 9.5:1 pistons, cometic head gasket, acl race bearings on all rotating assembly
1g rods, balance shaft removal kit, (oil port blocked accordingly) Rotating assembly fully balanced by Goza also matched & ground all piston rings for each cylinder + mated pistons to corrosponding cylinders for balance. All oil squirters still in place
head rebuilt by goza machine as well, valve job, new guides, etc
Ecm rebuilt with new capacitors etc + socketed by keydiver when he was still around
ECM Link v3
Precision 6262 dual ball bearing
AEM FPR
custom fabbed oil catch can
custom remote oil filter setup now uses sb GM filters larger + holds more oil
Afco Scirocco radiator + aftermarket fan
Tial Q BOV
JMF Sheet Metal Intake Manifold
Tial 38mm waste gate
Megan racing SS turbo manifold with custom waste gate flange
megan racing 2.5" SS tubular 02 housing
Extreme Motorsports 3" exhaust
4gperformance 3" custom intake piping
3" GM Maf + ECM link GM maf cable
JMF COP setup
Hallman manual boost controller
Jay racing alternator relocation kit w/ new alternator
Web cams(272 intake/276 exhaust)
Bosch 044 fuel pump in tank
Delphi 850cc injectors
4gperformance FMIC setup with ETS core
90 DSM external oil cooler
Drivetrain + Suspension:
Shepard Stage 1 Tranny with Evo steel shift forks
Spec stage 2 clutch with
Jesus_Negros
USA
I remember this car. GLWS
jnava
Arlington, Tx
Le crankwalks
Always loved this car too, so different and unique.
CutlassJim
Manchester, NH
strokin4dr
Savannah, GA
Pics of the underside and interior?
MellowVR4
Milwaukee, Wi
May I ask what you got for it?
