Unfortunately the time has come to sell my favorite car. Purchased it from the original owner last year. He had the car 100% stock with a large booklet of all the service work done to the car. Drove the car in the winter and when spring came I put it in the garage to fix the oil/power steering leaks it had. Well that turned into a full rebuild. Pulled the engine and trans out together. Replaced all gaskets and seals. Did an oem balance shaft delete also. Eliminated the rear steering since the rear lines were leaking, front power steering still works and feels great. Car has many upgrades, is extremely reliable and very fun to drive. My main intention on the build was to be a fast daily driver but still be reliable. Put a bit over 2k miles since I've finished. Mostly all parts installed were brand new. On to the long mod list...
GVR4 Mod List
Evo 9 intercooler with custom piping
New Stainless clutch line
Front strut bar from Malaysia
Newly rebuilt bolt on 20g turbo with cast wheel and 7mm housing
New Bullseye 3" intake with maf adapter and filter
Rebuilt throttle body
New Innovate wideband
New Prosport boost gauge
New Front camber kit
New FP race manifold
1g Megan downpipe
New 1g catback exhaust modified to fit
New NGK wires with bpr8 plugs
Rebuilt 1g power steering pump
New radiator
Ecu socketed with keydiver chip
New Pillar gauge pod
New Grimmspeed boost controller
New Non cruise throttle cable
New Miata battery with custom battery tray
New LR parking brake cable
New rear calipers, pads and rotors
Safc
New Chromoly subframe
Front Bilstein struts
New Rear AGX struts with eibach springs
New front lower control arms
Ralliart shift knob from Malaysia
New Ralliart racing steering wheel
New rally armor mud flaps
Buschar bolt on fpr with gauge
New FIC 750cc injectors
New Walbro 255
New STM filter to rail kit
New Mls headgasket
New Oem timing belt kit
New Oem balance shaft delete
New Arp headstuds
New 3mm oem lifters
New Intake manifold phenolic spacer
New aluminum Fidanza flywheel
New stage 3 dual friction clutch
New oem fulcrum ball, throw out bearing and clip
New redline fluid in trans, transfer and diff
Racing hart white with machined lip rims
2 new front tires
2 used rear tires with about 6/32nd left
Also have stock rims with good used tires on them
GVR4 Mod List
1g Megan downpipe
New radiator
Safc
New Walbro 255
New Mls headgasket
New Arp headstuds
New 3mm oem lifters
2 new front tires
